Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:scripting_reference:scripting_objects:script
The Script object is one of the two global script objects provided by Opus. This object is provided to script addins when their various event handlers are invoked (other than for the OnInit event). It provides information relating to the script itself.
The Script object is tied to the Script Add-In. Include Files and Modules do not get their own independent Script objects; their code is considered part of the Script Add-In which uses them. For example, if you use Script.vars from an include file, you'll get the same variables you'd get from code in the Script Add-In itself.
config
object:ScriptConfig
Returns a ScriptConfig object representing the configuration values for this script. In the OnInit method a script can define the properties that make up its configuration - the user can then edit these values in Preferences. The object returned by the config property represents the values that the user has chosen.
file
string
Returns the path and filename of this script.
vars
object:Vars
Returns a Vars object that represents the variables that are scoped to this particular script. This allows scripts to use variables that persist from one invocation of the script to another.
InitColumns
none
none
If your script implements the OnAddColumns event, you can call the InitColumns method at any time to reinitialize your columns. You may want to do this, for example, in response to the user modifying your script's configuration.
InitCommands
none
none
If your script implements the OnAddCommands event, you can call the InitCommands method at any time to reinitialize your commands. You may want to do this, for example, in response to the user modifying your script's configuration.
LoadImage
<string:name>
[<int:width>]
[<int:height>]
[<bool:alpha>]
object:Image
Loads an image file from the specified external file. If your script is bundled as a script package you can place image files in a sub-directory of the package called images and then load them from your script by giving their name.
If width and height are not provided, they default to 0, meaning the image is loaded at its native size. The width and height parameters only specify the desired size; the resultant image may be smaller or larger, and should be scaled after loading if you need it to be an exact size. The main purpose of the width and height parameters is to influence which image within an icon is loaded; most other image formats either ignore the parameters or only use them to speed things up, such as avoiding a full JPEG decode if a partial decode can satisfy the desired image size.
Images are loaded transparently (with alpha) by default; set the alpha argument to False if you want to disable that.
The returned Image object can be given as the value of the Control.label property for a static control in a script dialog (when that control is in "image" mode). You can also assign as to the icon property of a Dialog object to specify a custom window icon for your script dialog.
LoadResources
<string:name> or
<string:XML>
none
Loads external script resources and makes them available to the script. You can either provide a filename or a raw XML string. If your script is bundled as a script package, the resource file must have a .odxml extension for LoadResources to be able to find it in the package.
RefreshColumn
<string:name>
none
If your script implements any custom columns, you can use this method to cause them to be regenerated if they are currently shown in any tabs. You may want to do this, for example, in response to the user modifying your script's configuration. Pass the name of the column you want to regenerate as the argument to this method.
UpdateButtons
<bool:full>
none
Forces any dynamically-added and context-sensitive script buttons to be refreshed. Set the full argument to False to only refresh context-sensitive buttons. Set to True to also regenerate dynamic buttons.
UpdateConfig
none
none
When a script add-in starts up it receives a copy of its current configuration. This method lets you update that copy to reflect any external changes made to the script configuration.
UpdateFAYTFlags
<string:name>
<int:flags>
none
Lets a script add-in update the flags for a FAYT extension. This equates to the options shown to the user for the FAYT mode on the Quick Keys Preferences page.
The name should be the name of the FAYT extension command; this is given to your command as the ScriptFAYTCommandData.fayt property. The flags value should represent a flag combination that's meaningful to your extension.
