The OnAddColumns event is called to allow your script add-in to add columns. Call the AddColData.AddColumn method once for each column you wish to add.
Method Name: | OnAddColumns |
Argument Type: |
Return Type: |
none |
Description: |
When Opus starts up, or when a script add-in is added, edited or enabled, its OnAddColumns method is called. This allows a script to add columns :scripting:example_scripts:adding_a_new_internal_commandto Opus. A script can reinitialize its list of columns at any time by calling the Script.InitColumns method. |
