reference:scripting_reference:scripting_events:onafterfolderchange
The OnAfterFolderChange event can be implemented by a script add-in that wants to be notified after a new folder has been read in a tab. Use the OnBeforeFolderChange event to receive notification before the folder is read.
Method Name: OnAfterFolderChange
Argument Type:
AfterFolderChangeData
Return Type:
bool
Description:
The AfterFolderChangeData.tab property indicates the tab and the path property the path of the folder. The result property indicates the success or failure of the folder read.
If result is False (i.e. the folder was not successfully read) then you can return True from this event to stop Opus from going back to the previous folder (which is what normally happens when a folder read fails). If result is True then the return value from this event is ignored.
