reference:scripting_reference:scripting_events:onlisteruichange
The OnListerUIChange event can be implemented by a script add-in to receive notification when the state of certain user interface elements in the Lister changes.
Method Name: OnListerUIChange
Argument Type:
ListerUIChangeData
Return Type:
none
Description:
The ListerUIChangeData.lister property identifies the Lister, and the change property is a string indicating the element that changed. You can discover the actual state of the element using the Command.IsSet method.
