DOpusRT is a separate program (dopusrt.exe) that performs various support functions for Directory Opus:
The program dopusrt.exe is located in the main Opus program folder (normally C:\Program Files\GPSoftware\Directory Opus). Note that if you are invoking DOpusRT from an Opus button or hotkey, you don't need to use the full path - you can use the dopusrt keyword as a shortcut for the actual location of the .exe. Otherwise, you would normally need to specify the full path of the command when using it (for example, in a shortcut or a batch file). In the examples below, the full path is omitted for clarity.
The DOpusRT command line consists of a command followed by arguments appropriate to that command. For completeness, all dopusrt.exe commands are listed here - but many are designed to only be used by Opus itself. The commands you will most probably be interested in are are /cmd and /col.
Command | Arguments | Description |
/acmd |
<command and arguments> |
Invokes an Opus command from outside of Opus. If one or more Opus listers are open, the command is sent to the one which is, or was most recently, the active window. Equivalent to /cmd:active. Example: dopusrt.exe /acmd Go "C:\Program Files" |
/argsmsgbox |
(no arguments) |
Displays any remaining arguments in a message box. This can be useful when you wish to see the exact command-line that an Opus command is generating when calling an external command. Example: dopusrt.exe /argsmsgbox Hello World |
/argstoclip |
(no arguments) |
Puts any remaining arguments into the clipboard. As with /argsmsgbox, this can be useful for checking what Opus would pass to an external command. Note that Opus has a built-in Clipboard command which is a better choice if you just want to put some text or filenames into the clipboard. Example: dopusrt.exe /argstoclip Hello World |
/changelanguage |
<language> |
Changes the user-interface language. Opus will restart, and toolbars and menus will be translated (if possible). Example: dopusrt.exe /changelanguage deutsch |
/cmd[:type] |
Invokes an Opus command from outside of Opus. If no type parameter is specified, and one or more Opus Listers are open, the command is sent to the Source window. The optional type parameter accepts the following keywords:
Examples: dopusrt.exe /cmd Go C:\ NEW=0,0,640,480 |
/col |
<collection command> |
Lets you manipulate file collections from outside of Opus. See the External Manipulation of File Collections page for more information. Example: dopusrt.exe /col create "Holiday Photos" |
/dblclk |
(no arguments) |
Runs in the background to manage the double-click on the desktop feature. You do not need to run this command manually - Opus starts it automatically when the desktop double-click option is enabled. |
=off |
Deactivate a running double-click manager. You can use this command if you want to temporarily disable the desktop double-click feature (rather than using Task Manager to kill the dopusrt.exe instance). Example: dopusrt.exe /dblclk=off |
/dde |
(no arguments) |
Run a DDE server to listen for DDE commands relating to opening folders. This is used in Explorer Replacement mode when you double-click on a folder. You do not need to run this command manually. |
/delay |
=<seconds> |
Only valid after /dblclk. Causes the desktop double-click functionality to wait the specified number of seconds before setting itself up. This can be used to work around conflicts with other software that will break desktop double-click if it starts later in the Windows boot cycle. Example: dopusrt.exe /dblclk /delay=10 |
/flushplugins |
(no arguments) |
Flush viewer plugins from memory. If Opus is running, any plugins not currently in use will be unloaded. You can use this if you are developing a plugin and want to replace the DLL file without having to quit Opus. Example: dopusrt.exe /flushplugins |
/help |
<help path> |
Displays the specified document from the local help in your web browser. This is used to implement the opushelp:// URL scheme, which Opus registers when it's installed. |
/info |
<information command> |
Lets you retrieve information about the currently displayed folders and files from outside of Opus. See the Retrieving File and Folder Information page for more information. Example: dopusrt.exe /info path_list.txt,paths |
/open |
<folder path> |
Opens a new Lister showing the specified path. Example: dopusrt.exe /open "C:\Program Files" |
/restart |
(no arguments) |
Restarts Opus if it is already running. If Opus is not already running it will be started. Example: dopusrt.exe /restart |
:norun |
Restarts Opus if it is already running, but does not start it if it is not running. Example: dopusrt.exe /restart:norun |
/runopus |
(no arguments) |
Starts Opus if it is not already running. Under Vista and above, this will always launch Opus as non-elevated, even if the process invoking dopusrt.exe is elevated. Example: dopusrt.exe /runopus |
/runstd |
<command line> |
Lets you launch another program. Under Vista and above, this will run the specified command as non-elevated, even if the process invoking dopusrt.exe is elevated (this is really the only point of this command). Example: dopusrt.exe /runstd notepad.exe |
/show |
<filename> |
Shows the specified file using the Opus standalone viewer. You could use this to make the Opus viewer the default system image viewer for a file type. Example: dopusrt.exe /show %1 |
/vcmd |
Invokes an Opus command from outside of Opus, in the context of the currently (or most recently) active image viewer. If no image viewers are open the command will be ignored. Equivalent to /cmd:viewer. Example: dopusrt.exe /vcmd Show VIEWERCMD=selectall |
<filename> |
(no arguments) |
DOpusRT can be called with the name of an external file to launch various Opus files. This behaviour is used by the default file type associations that Opus creates - for example, a .dcf file (an Opus command file, created by dragging a toolbar button to the desktop in Customize mode) is launched by passing its filename to dopusrt.exe. The file types that can be invoked in this way are .dcf (command files), .dpf (exported Preferences files from older versions of Opus) and .dop (toolbars). Example: dopusrt.exe C:\Commands\NewLister.dcf |
More:
