reference:scripting_reference:scripting_events:onopentab
The On event can be implemented by a script add-in to receive notification when a new tab opens.
Method Name: OnOpenTab
Argument Type:
OpenTabData
Return Type:
none
Description:
The OpenTabData.tab property identifies the newly opened tab. Note that this method is not called when a new Lister is opened, irrespective of how many tabs it contains - instead, you can identify all the tabs in the newly opened Lister by implementing the OnOpenLister event.
