reference:scripting_reference:scripting_events:onfilesystemchange
The OnFilesystemChange event can be implemented by a script add-in to receive notification when monitored files or folders change. Monitoring is established by calling the FSUtil.WatchChanges method.
Method Name: OnFilesystemChange
Argument Type:
FilesystemChangeData
Return Type:
none
Description:
The id property indicates which watcher detected a change. Note that you aren't told what changed, only that something meeting the specified conditions did change.
