Sidebar
reference:scripting_reference:scripting_objects:quickfilter
The QuickFilter object provides access to information about the quick filter state in a tab. It’s returned by the Tab.quickfilter property.
<default value>
string
Returns the current filter string, if any.
autoclear
bool
Returns True if the auto-clear mode is set in Preferences.
autostar
bool
Returns True if the auto-star mode is set in Preferences.
disable
bool
Returns True if the filter is disabled.
easymode
bool
Returns True if easy mode is selected.
filter
string
Returns the current filter string.
flatview
bool
Returns True if folder filtering in flatview is on.
hidealldirs
bool
Returns True if all folders are being hidden.
hideallfiles
bool
Returns True if all files are being hidden.
overrideflatview
bool
(Legacy flag.) Returns True if folder filtering in flatview is overrriden. Use the flatview flag to find out if it is actually on or off.
partial
bool
Returns True if partial matching is enabled.
realtime
bool
Returns True if realtime filtering is enabled.
regex
bool
Returns True if regular expression mode is enabled.
showalldirs
bool
Returns True if all folders are being shown.
showallfiles
bool
Returns True if all files are being shown.
showeverything
bool
Returns True if Show Everything mode is on, which overrides (almost) all filtering.
