Sidebar
reference:scripting_reference:scripting_objects:smartfavorite
A SmartFavorite object represents an entry for a folder in the SmartFavorites table. It is retrieved by enumerating or indexing the SmartFavorites object.
path
object:Path
Returns the path this entry represents, as a Path object.
points
int
Returns the number of points this entry has as a source folder. The point score is used by Opus to determine which folders to display.
destpoints
int
Returns the number of points this entry has as a destination folder.
