Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:scripting_reference:scripting_objects:listerresizedata
If a script add-in implements the OnListerResize event, the method receives a ListerResizeData object whenever a Lister window is resized.
action
string
Returns a string indicating the resize action that occurred. This will be one of the following strings: resize, minimize, maximize, restore.
width
int
Returns the new width of the Lister in pixels.
height
int
Returns the new height of the Lister in pixels.
lister
object:Lister
Returns a Lister object representing the Lister that was resized.
