The TabGroup object represents a folder tab group or a folder into which other tab groups can be organized. Individual TabGroup objects can be accessed or enumerated from the TabGroups object.
| Property Name | Return Type | Description |
closeexisting |
bool |
True if the Close existing folder tabs when opening this group option is turned on for this group. Only present when the folder property is False. |
desc |
string |
The description of this tab group, if any. Only present when the folder property is False. |
dual |
bool |
True if the Define tabs on specific sides of a dual-display Lister option is turned on for this group. Only present when the folder property is False. |
folder |
bool |
True if this object represents a folder within the tab group list, False if it's an actual tab group. |
hidden |
bool |
True if this tab group or folder should be hidden from menus which list tab groups. The group will still always be visible in Preferences. |
lefttabs |
object:TabGroupTabList |
Returns a TabGroupTabList object representing the tabs in this group that open in the left/top side of a dual-display Lister. Only present when the folder property is False and the dual property is True. |
name |
string |
The name of this group or folder. |
righttabs |
Returns a TabGroupTabList object representing the tabs in this group that open in the right/bottom side of a dual-display Lister. Only present when the folder property is False and the dual property is True. |
tabs |
Returns a TabGroupTabList object representing the tabs in this group. Only present when both the folder and dual properties are False. |
| Method Name | Arguments | Return Type | Description |
AddChildFolder |
<object:TabGroup> or <string:name> |
object:TabGroup |
Adds a new sub-folder to this tab group folder. Only available when the folder property is True. You can either provide a TabGroup object (which itself has the folder property set to True) or the name for the new folder. If the operation succeeds a TabGroup object is returned which represents the new folder. If the operation fails False is returned. |
AddChildGroup |
object:TabGroup |
Adds a new tab group to this tab group folder. Only available when the folder property is True. You can either provide a TabGroup object or the name for the new group. If the operation succeeds a TabGroup object is returned which represents the new tab group. If the operation fails False is returned. |
DeleteChild |
<object:TabGroup> |
none |
Deletes the child item (folder or tab group). |
Duplicate |
none |
object:TabGroup |
Returns a duplicate of this tab group or folder. When it's returned the duplicate has not yet been added to a tab list. |
Link |
<object:TabGroupTabEntry> |
none |
In a tab group that has specific left and right tabs specified, this method links together a tab from the left side and a tab from the right side. Only available if the dual property is set to True. You can provide TabGroupTabEntry objects or the index numbers of the tabs you want to link. The optional type parameter can be set to "slave" to specify that the tabs should be slaved to each other. |
Unlink |
none |
Unlinks the specified tab from its partner. Only available if the dual property is set to True. |
