Sidebar
reference:scripting_reference:scripting_objects:fileoperationcompletedata
If a script add-in implements the OnFileOperationComplete event, the method receives a FileOperationCompleteData object whenever a supported file operation begins. If you return True to indicate that you want to be notified about the operation, you'll receive another call when the operation is complete.
action
string
Returns a string that indicates the type of file operation. Currently the only supported value is "rename".
cmdline
string
Returns a string that provides the entire command line that launched this operation.
data
variant
When the query property is False this provides further information about the operation that completed.
For "rename" this returns a Map object that provides a map of all items that were renamed and their new names.
dest
object:Path
Returns a Path object representing the destination path of the operation.
qualifiers
string
Returns a string indicating any qualifier keys that were held down by the user when the operation was initiated.
The string can contain any or all of the following: shift ctrl, alt, lwin, rwin
If no qualifiers were down, the string will be: none
query
bool
Returns True the first time the OnFileOperationComplete event is called. You should examine the action and other properties and return True if you decide you want notification about this operation. This will be False when you are called the second time, when the operation is complete.
source
object:Path
Returns a Path object representing the source path of the operation.
tab
object:Tab
Returns a Tab object representing the source folder tab.
