The DialogListColumn object represents a column in a Details mode list view control in a script dialog. Use the Control.columns property to obtain a DialogListColumns object, and then enumerate it to obtain individual DialogListColumn objects.
Property Name | Return Type | Description |
name |
string |
Returns or sets the column's name. |
resize |
bool |
Set this property to True if you want this column to automatically resize when the list view is resized horizontally. Only one column can be set to auto-resize at a time. |
sort |
int |
Returns 1 if the list view is currently sorted forwards by this column, -1 if it's currently sorted backwards by this column, or 0 otherwise. Settings this property will re-sort the list. |
width |
int |
Returns or sets the column's width in pixels. Set it to -1 to automatically size the column to fit its content. You can automatically resize all columns at once using the DialogListColumns.AutoSize method. |
