Sidebar
reference:scripting_reference:scripting_objects:activatelisterdata
If a script add-in implements the OnActivateLister event, the method receives an ActivateListerData whenever the window activation state of a Lister changes.
active
bool
Returns True if this Lister is activating, False if deactivating. Note that if the activation moves from one Lister straight to another the script will be called twice.
lister
object:Lister
Returns a Lister object representing the Lister that is closing.
qualifiers
string
Returns a string indicating any qualifier keys that were held down by the user when the event was triggered.
The string can contain any or all of the following: shift ctrl, alt, lwin, rwin
If no qualifiers were down, the string will be: none
