Sidebar
reference:scripting_reference:scripting_objects:tabclickdata
If a script add-in implements the OnTabClick event, the method receives a TabClickData object when a tab is clicked with a qualifier key held down.
qualifiers
string
Returns a string indicating any qualifier keys that were held down by the user when the event was triggered.
The string can contain any or all of the following: shift ctrl, alt, lwin, rwin
If no qualifiers were down, the string will be: none
tab
object:Tab
Returns a Tab object representing the tab that was clicked.
