Sidebar
reference:scripting_reference:scripting_objects:lister
The Lister object represents an open Lister window. A collection of currently open Lister objects is available from the DOpus.listers property, and if a command results in a new Lister being opened, the Results object.
activetab
object:Tab
Returns a Tab object representing the currently active (source) tab.
bottom
int
Lister window bottom-edge coordinate.
custom_title
string
Returns the custom title of the Lister (if any) as set by the Set LISTERTITLE command. This may be an empty string. The title property returns the actual window title.
desktop
string
Returns the ID of the virtual desktop this Lister is on.
desttab
object:Tab
Returns a Tab object representing the current destination tab (in a dual-display Lister).
dual
int
Indicates whether the Lister is in dual-display mode or not. Possible values are:
0single-display mode
1dual-display, vertical layout
2dual-display, horizontal layout
dualsize
int
Returns the current split percentage of the dual displays (e.g. 50 indicates they are evenly sized).
foreground
bool
Returns True if this Lister is currently the foreground (active) window.
lastactive
bool
Returns True if this Lister is currently the active Lister (foreground window), or was the most recently active Lister.
layout
string
Provides the name of the Lister layout that this Lister came from (if any).
left
int
Lister window left-edge coordinate.
metapane
int
Indicates whether the metadata pane is currently open or not. Possible values are:
0metadata pane is not open
1metadata pane is open, vertical layout
2metadata pane is open, horizontal layout
right
int
Lister window right-edge coordinate.
state
string
Returns the state of a single-display mode Lister:
0off
1source
2destination
4locked
style
string
Returns the name of the Lister style which was last applied to the Lister, or an empty string if there is none. This is just the last style which was loaded and does not mean the Lister still looks the same; the user may have opened or closed panels and made other changes via other methods in the time since the style was applied.
tabs
collection:Tab
Returns a collection of Tab objects that represent all tabs in this Lister. In a dual-display Lister this includes tabs in both the left and right file displays.
tabgroupleft
string
Returns the name of the Folder Tab Group which was last loaded into the left half of the Lister, or an empty string if no group has been loaded.
The name only changes when a Folder Tab Group is loaded. The current tabs may no longer resemble the named tab group if the user has made changes since the group was loaded. The name persists across restarts, through the Default Lister and saved Layouts.
tabgroupright
string
Similar to tabgroupleft, above, but for the right half of the Lister (if any).
tabsleft
collection:Tab
Returns a collection of Tab objects that represent the tabs in the left/top side of a dual-display Lister. In a single-display Lister this is equivalent to all the tabs in the Lister.
tabsright
collection:Tab
Returns a collection of Tab objects that represent the tabs in the right/bottom side of a dual-display Lister. In a single-display Lister this will return an empty collection.
title
string
Returns the current title of the Lister window.
toolbars
collection:Toolbar
Returns a collection of Toolbar objects representing all currently open toolbars in this Lister.
The collection is obtained directly each time the script asks for it, and is not a snapshot, so you don't need to call Update for it to reflect changes.
top
int
Lister window top-edge coordinate;
tree
int
Indicates whether or not the folder tree is currently open. Possible values are:
0folder tree is not open
1a single tree is open, at the left of the Lister
2a single tree is open, at the right of the Lister
3two folder trees are open (in a dual-display Lister)
utilpage
string
If the utility panel is currently open, returns a string indicating the currently selected utility page. Possible values are find (which means the Find panel's Simple version), findadvanced, sync, dupe, undo, filelog, ftplog, otherlog, email.
utilpane
int
Indicates whether or not the utility panel is currently open. Possible values are:
0utility panel is not open
1utility panel is open
vars
object:Vars
This Vars object represents all defined variables with Lister scope (that are scoped to this Lister).
viewpane
int
Indicates whether or not the viewer pane is currently open. Possible values are:
0viewer pane is not open
1viewer pane is open, vertical layout
2viewer pane is open, horizontal layout
viewpanefile
object:Path
Returns the path of the file currently displayed by the lister's viewer pane. The path will be an empty string if there is no file currenly displayed.
The path is obtained directly each time the script asks for it, and is not a snapshot, so you don't need to call Update for it to reflect changes.
windowstate
string
Returns the current visibility state of the Lister window. Possible values are:
minthe Lister is minimized
maxthe Lister is maximized
hiddenthe Lister is hidden
normalthe Lister is displayed normally
Dlg
none
object:Dialog
Creates a new Dialog object, that lets you display dialogs and popup menus. The dialog's window property will be automatically assigned to this Lister.
IsOnCurrentDesktop
none
bool
Returns True if the Lister is on the current virtual desktop.
MoveToDesktop
<string:desktop>
bool
Moves the Lister window to the specified virtual desktop. Returns True if successful.
SetTaskbarGroup
<string:group>
bool
Used to change how the Lister window is grouped with other Opus windows on the taskbar. Specify a group name to move the window into an alternative group, or omit the group argument to reset back to the default group. If one or more windows are moved into the same group, they will be grouped together, separate from other the default group.
This only works when taskbar grouping is enabled. Group names are limited to 103 characters and will be truncated if longer. Spaces and dots in group names are automatically converted to underscores. Returns True on success.
Update
none
none
The first time a script accesses a particular Lister object, a snapshot is taken of the Lister state. If the script then makes changes to that Lister (e.g. it opens a new tab, or moves the window), these changes will not be reflected by the object (unless otherwise mentioned). To re-synchronize the object with the Lister, call the Lister.Update method.
