Sidebar
reference:scripting_reference:scripting_objects:filetypegroup
The FiletypeGroup object represents a file type group (as configured in the File Type Groups section of the file type editor). You can find out which groups a file belongs to by querying the Item.groups property, or by using the FiletypeGroups object.
Note: If you're looking for information on how the file display is grouping an item based on one of the displayed columns, rather than which file type group a file is part of, see the FileGroup object instead.
This object can be enumerated to retrieve the file extensions it represents.
<default value>
string
Returns the internal name of this group.
The internal name is always the same in all languages.
Groups that come pre-defined when you install Opus have internal names like "Archives" and "Music" (which are also their English display names).
User-defined groups have internal names which are unique, automatically generated GUID strings like "{C4B716ED-2A9C-43C6-B325-7DADDEEFADA9}".
display_name
string
Returns the display name of this group.
The display name is what you see in the File Types editor. Display names may be translated differently in different languages.
tiles
string
Returns the tiles mode definition string for this group.
tooltip
string
Returns the tooltip definition string for this group.
MatchExt
<string:filename>
bool
Tests the filename (or extension) for membership of this group. Returns True if the file is a member of the group, or False if it is not.
