Sidebar
reference:scripting_reference:scripting_objects:fontmeta
The FontMeta object is retrieved from the Metadata.font property. It provides access to metadata relating to font files. The fields in this object correspond to those in the Windows SDK LOGFONT structure; further information about their meaning can be found on the MSDN website.
charset
int
The character set.
clipprecision
int
The clipping precision.
escapement
int
The angle, in tenths of degrees, between the escapement vector and the x-axis of the device.
fontname
string
The typeface name of the font.
height
int
The height, in logical units, of the font's character cell or character.
italic
bool
An italic font if set to True.
orientation
int
The angle, in tenths of degrees, between each character's base line and the x-axis of the device.
outprecision
int
The output precision.
pitchandfamily
int
The pitch and family of the font.
quality
int
The output quality.
strikeout
bool
A strikeout font if set to True.
underline
bool
An underlined font if set to True.
weight
int
The weight of the font in the range 0 through 1000.
width
int
The average width, in logical units, of characters in the font.
