Sidebar
reference:scripting_reference:scripting_objects:fileattr
The FileAttr object is provided to make it easier to deal with file attributes. Rather than dealing with attributes as a string of characters, or a number, it provides properties for each attribute that can be set or queried independently. You can create a new FileAttr object using the FSUtil.NewFileAttr method. FileAttr objects are also returned by properties of the Format and Item objects.
Each attribute is represented by two properties; a single character (e.g. a) and its full name (e.g. archive). Each property returns True if the attribute is set, and False if not. For FileAttr objects you create yourself, you can also set the value of these properties (and then, for example, apply the attributes to a file using the File.SetAttr method).
<default value>
string
Returns a string representing the attributes that are set (similar to the format displayed in the Attr column in the file display).
a
archive
bool
A file or directory that has changes which need archiving. The A bit is usually set on new or modifies files, and may then be cleared by backup software after it has added the changes to a backup.
c
compressed
bool
A file or directory that is compressed. For a file, all of the data in the file is compressed. For a directory, compression is the default for newly created files and subdirectories.
e
encrypted
bool
A file or directory that is encrypted. For a file, all data streams in the file are encrypted. For a directory, encryption is the default for newly created files and subdirectories.
h
hidden
bool
The file or directory is hidden. It is not included in an ordinary directory listing.
i
nonindexed
bool
The file or directory is not to be indexed by the content indexing service.
o
offline
bool
The data of a file is not available immediately. This attribute indicates that the file data is physically moved to offline storage. This attribute is used by Remote Storage, which is the hierarchical storage management software. Applications should not arbitrarily change this attribute.
p
pinned
bool
The data of the file is to be kept available at all times; it should not be offloaded to offline storage.
r
readonly
bool
A file that is read-only. Applications can read the file, but cannot write to it or delete it. This attribute is not honored on directories.
s
system
bool
A file or directory that the operating system uses a part of, or uses exclusively.
Assign
object:FileAttr\\ or string
none
Assigns a new set of attributes to this object. You can pass another FileAttr object, or a string (e.g. "hsr").
AttrName
string
string
Given a single character representing an attribute (e.g. "a") this method returns the name of the attribute in the user's current language (e.g. "Archive").
Clear
none
Clears (turns off) the specified attributes in this object. You can pass another FileAttr object, or a string representing the attributes to turn off.
Set
none
Sets (turns on) the specified attributes in this object. You can pass another FileAttr object, or a string representing the attributes to turn on.
ToString
none
none
