The UnorderedSet object is container that stores one or more unique objects. It is similar to a StringSet except it can store variants of any type (rather than just strings), and the contents are not kept sorted (in fact, the order of set members is unspecified). Like a StringSet it uses a dictionary system to locate members rather than numeric indexes. You can therefore lookup members much more quickly than by linearly searching a Vector.
You can create a new UnorderedSet using the DOpusFactory object.
Care should be taken when adding objects to an UnorderedSet. Unlike strings and numbers, the container will only consider two objects equal if both are the exact same object (i.e. same instance/reference). Two separate objects with the same value will not be considered equal, and can both exist in the same UnorderedSet at once.
var us = DOpus.Create.UnorderedSet(); us.insert("cat"); us.insert("cat"); // No effect, as "cat" already inserted. us.insert("dog"); us.insert(DOpus.FSUtil.NewPath("C:\\")); us.insert(DOpus.FSUtil.NewPath("C:\\")); // Inserts a second C:\ Path object! var p = DOpus.FSUtil.NewPath("D:\\"); us.insert(p); us.insert(p); // No effect, as p already inserted. DOpus.Output("count: " + us.count); for (var e = new Enumerator(us); !e.atEnd(); e.moveNext()) { DOpus.Output("Item: " + e.item()); }
That will output the following (order of items may vary):
count: 5 Item: cat Item: dog Item: D:\ Item: C:\ Item: C:\
Property Name | Return Type | Description |
count |
int |
Returns the number of elements the UnorderedSet currently holds. |
empty |
bool |
Returns True if the UnorderedSet is empty, False if not. |
length |
int |
A synonym for count. |
size |
int |
Method Name | Arguments | Return Type | Description |
assign |
<UnorderedSet:from> |
none |
Copies the contents of another UnorderedSet to this one. You can also pass an array or Vector object. |
clear |
none |
none |
Clears the contents of the UnorderedSet. |
erase |
variant |
none |
Erases the element if it exists in the set. |
exists |
variant\\ |
bool |
Returns True if the specified element exists in the set. |
insert |
variant |
bool |
Inserts the element into the set if it doesn't already exist. Returns True if successful. |
merge |
none |
Merges the contents of another UnorderedSet with this one. |
