Sidebar
reference:scripting_reference:scripting_objects:folderenum
The FolderEnum object is returned from the FSUtil.ReadDir method. It lets you enumerate (optionally, recursively) the contents of a folder.
complete
bool
True if the enumeration is complete, otherwise False.
error
int
If an error occurs this will return the error code. It will return 0 on success.
Close
none
none
Closes the underlying file system handle used to perform the enumeration. You might call this method if you want to delete the folder you just enumerated. After this method is called the complete property will return True.
<int:count>
<Vector:vector>
object:Item
or
object:Vector
Returns the next item in the enumeration.
By default (with no arguments provided) a single Item object is returned. For higher performance, you can specify a number as the first argument to return more than one item at once - in this case, a Vector of Item objects is returned instead. Specify -1 to return all items in the folder in one call.
You can also create your own Vector and pass it as the second argument to stop Opus creating a new Vector each time.
