Sidebar
reference:scripting_reference:scripting_objects:globalfilters
The GlobalFilters object provides information about the global file and folder filter settings (configured on the Filters page in Preferences). It is obtained from the DOpus.filters property.
enable
bool
Returns True if the global wildcard filters are enabled.
file
string
Returns the global filename filter wildcard pattern. If the wildcard is configured to use regular expressions, it will have a regex: prefix in front of the pattern.
folder
string
Returns the global folder filter wildcard pattern. If the wildcard is configured to use regular expressions, it will have a regex: prefix in front of the pattern.
hidehidden
bool
Returns True if the global option to hide hidden files is on.
hidesystem
bool
Returns True if the global option to hide operating system files is on.
