Sidebar
reference:scripting_reference:scripting_objects:results
The Results object provides information about the outcome of a function run by the Command object. It is obtained from the Command.results property.
result
int
Indicates whether or not the command ran successfully. Zero indicates the command could not be run or was aborted; any other number indicates the command was run for at least some files. (Note that this is not the "exit code" for external commands. For external commands it only indicates whether or not Opus launched the command. If you need the exit code of an external command, use the WScript.Shell Run or Exec methods to run the command.)
newtabs
collection:Tab
This property returns a collection of Tab objects representing any new tabs created by the command.
newlisters
collection:Lister
This property returns a collection of Lister objects representing any new Listers created by the command.
newviewers
collection:Viewer
This property returns a collection of Viewer objects representing any new image viewers created by the command. (This is only for standalone viewers, not the viewer pane.)
