Sidebar
reference:scripting_reference:scripting_objects:scriptcommanddata
The ScriptCommandData object is passed to the script-defined entry points for any internal commands added by a script add-in. The method name for these events is defined by the script itself, but generically it's referred to as OnScriptCommand.
cmdline
string
This returns the original command line that invoked the command. If any arguments were provided on the command line they are available in parsed form from the func.args property.
fayt
string
or bool
If this is a string, it means this is being called as a FAYT extension command. If set to False it's a regular command.
func
object:Func
Returns a Func object relating to this function. This provides access to information about the function's environment (source and destination tabs, etc) as well as any variables and parsed command line arguments.
