Sidebar
reference:scripting_reference:scripting_objects:filetypegroups
The FileTypeGroups object represents a collection of FiletypeGroup objects. The object can be enumerated to retrieve the groups it represents.
You can obtain an object representing all the configured file type groups from the DOpus.filetypegroups property. The Item.groupsobject property returns a FiletypeGroups object restricted to just the groups the Item is a member of.
<default value>
collection:FiletypeGroup
Lets you enumerate the file type groups represented by this object.
GetGroup
<string:group>
object:FiletypeGroup
or
bool (False)
Searches the file type group collection for the named group.
If Opus is not running in English, the translated name is compared first; if not found, it will search for the native English name for the built-in groups.
Returns a FiletypeGroup object or False if not found.
MatchExt
<string:filename>
object:FiletypeGroups
Returns a new FiletypeGroups object containing the subset of groups that the specified filename (or file extension) is a member of. You would normally only call this method on the object returned by the DOpus.filetypegroups property.
Translate
<string:group>
string
Returns the translated name of the named built-in file type group.
If not found, or no translation exists, the input string is returned.
For example, when running in French, calling this method with "Movies" as the input string would return "Vidéos".
