Sidebar
reference:scripting_reference:scripting_objects:var
Var
The Var object represents an individual user or script-defined variable. Individual Var objects can be accessed or enumerated from the Vars object.
<default value>
variant
or string
The default value of the Var object returns the value of the variable itself, with one exception. If the Var object is being accessed as part of an enumeration of the Vars collection, the default value returns the variable name.
So for instance,
For Each Var in DOpus.Vars
DOpus.Output("Variable name = " & Var)
Next
Versus:
Set Var = DOpus.Vars("myvar")
DOpus.Output("Variable value = " & Var)
name
string
Returns the name of the variable. You cannot change the name of a variable once it has been assigned - instead, delete the variable from its collection and add a new one.
persist
bool
Returns True if the variable is persistent (saved) or False if not. You can set this property to change the persistence state.
value
variant
Returns the value of the variable. You can set this property to change the value of the variable.
You can store any type of variable in a Var object, although not all types can be saved to disk. If you want your variable to be persistent you should only use bool, int, string, date, currency or a Vector of those types.
Delete
none
none
Deletes this variable from its parent collection.
