Sidebar
reference:scripting_reference:scripting_objects:scriptfaytcommand
When a script calls the ScriptInitData.AddCommand method to add commands to the Opus internal command set, the ScriptCommand object it retrieves provides a ScriptFAYTCommand object in the fayt property. You can initialise this object to create a command that extends the FAYT field.
backcolor
string
Specify the default background color for your FAYT extension. This should be in the form #RRGGBB (hexadecimal) or RRR,GGG,BBB (decimal). You should use this and the textcolor property to specify both dark and light colors as the same, otherwise use the dark and light properties.
dark
object:ScriptColorPair
Use the ScriptColorPair object this returns to specify the default dark mode text and background colors for your FAYT extension (and use the light property to specify the light mode colors). If you want the default dark and light colors to be the same, you can use the textcolor and backcolor properties instead.
enable
bool
Set this property to True to enable the FAYT extension.
flags
object:Map
Lets you specify a set of flags that the user will be able to turn on or off through the user interface. To use this, you need to assign the property to a Map object created by the DOpus.Create.Map method.
Each flag should be added to the map with its numeric value (a power of two; e.g. 1, 2, 4, 8, …) as the key and its label as the value. When your FAYT extension is called, Opus will add the values of the flags the user has chosen together and pass them to your command.
The maximum number of flags you can add is 16.
key
string
Lets you specify a default key for your FAYT extension. Pushing this key from a file display or FAYT field will invoke the script.
label
string
This lets you specify a label for your FAYT extension which is shown in the user interface. If not supplied, the name of the command is used.
light
Use the ScriptColorPair object this returns to specify the default light mode text and background colors for your FAYT extension (and use the dark property to specify the dark mode colors). If you want the default dark and light colors to be the same, you can use the textcolor and backcolor properties instead.
realtime
bool
or int
Set to True to have your extension called in realtime as the user types. If set to False your extension will be called only when the user presses Enter. If set to an integer value, this specifies the number of milliseconds between when the user types and your script is called (i.e. deferred notification).
textcolor
string
Specify the default text color for your FAYT extension. This should be in the form #RRGGBB (hexadecimal) or RRR,GGG,BBB (decimal). You should use this and the backcolor property to specify both dark and light colors as the same, otherwise use the dark and light properties.
wantempty
bool
Set to false if you don't want to be called for a suggestion list for an empty string (i.e. the user must type something before your extension is invoked).
