Sidebar
reference:scripting_reference:scripting_objects:beforefolderchangedata
If a script add-in implements the OnBeforeFolderChange event, the method receives a BeforeFolderChangeData object before the new folder is read.
action
string
Returns a string indicating the action that triggered the folder read. The string will be one of the following: normal, refresh, refreshsearch, refreshsub, parent, root, back, forward, dblclk.
The refreshsub actions means the folder (and sub-folders) are being refreshed while Flat View is on. The other action names should be self-explanatory.
initial
bool
Returns True if this is the first path to be read into this tab (i.e. previously the tab was empty).
path
object:Path
Returns a Path object representing the new path that is to be read.
qualifiers
string
Returns a string indicating any qualifier keys that were held down by the user when the event was triggered.
The string can contain any or all of the following: shift ctrl, alt, lwin, rwin
If no qualifiers were down, the string will be: none
tab
object:Tab
Returns a Tab object representing the tab that is changing folder.
