Sidebar
reference:scripting_reference:scripting_objects:includefileinitdata
If an include file implements the optional OnInitIncludeFile event, an IncludeFileInitData object is passed to it to let it provide information about itself. This is completely optional; include files still work without this method, but providing it gives you things like a description and copyright information, and minimum version requirements.
copyright
string
Lets you provide copyright information for the include file.
desc
string
Provides a description of the include file.
min_version
string
Lets you specify a minimum version of Opus that the include file returns. If the current version is less than the specified version the include file will be disabled. You can specify the major version only (e.g. "13"), a major and minor version (e.g. "13.3") or a specific beta version (e.g. "13.3.1" for 13.3 Beta 1).
name
string
Provides a display name for the include file.
shared
bool
If the include file is inside a script package, setting this property to True makes the include file available to scripts outside that package. If set to False only scripts in the same package can include it.
url
string
Provides a URL which you might, for example, use to link to more information about the include file.
version
string
Lets you provide a version number for your include file.
