Sidebar
reference:scripting_reference:scripting_objects:dpi
The DPI object is a helper object that provides a number of methods and properties relating to the system DPI setting. For example, you can use it to convert a pixel width into one scaled for the current system DPI. The DPI object is returned via the DOpus.DPI property.
dpi
int
Returns the system DPI setting as a “dpi value” (e.g. 96, 192).
factor
int
Returns the DPI settings as a “scale factor” (e.g. 100, 125, 200).
Divide
<int:value>
int
Divides the provided size by the system DPI; e.g. if the system DPI was set to 150%, DPI.Divide(60) would return 40.
Scale
<int:value>
int
Scales the provided size by the system DPI; e.g. if the system DPI was set to 200%, DPI.Scale(75) would return 150.
