Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:scripting_reference:scripting_objects:videometa
The VideoMeta object is retrieved from the Metadata.video or Metadata.video_text properties. It provides access to metadata relating to movie files.
<column keyword>
variant
Returns the value of the specified column, as listed in the Movies section of the Keywords for Columns page.
