Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:scripting_reference:scripting_objects:imagemeta
The ImageMeta object is retrieved from the Metadata.image or Metadata.image_text properties. It provides access to metadata relating to picture files.
<column keyword>
variant
Returns the value of the specified column, as listed in the Pictures section of the Keywords for Columns page.
