Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:scripting_reference:scripting_objects:getcustomfielddata
If a rename script implements the OnGetCustomFields event, the method receives a GetCustomFieldData object whenever the Rename dialog runs the script.
fields
object:CustomFieldData
Returns a CustomFieldData object, that the script can use to add custom fields to the Rename dialog. Each property added to the object in this method will be create a new field in the dialog, allowing the user to supply additional information to your rename script.
field_labels
object:Map
This lets you assign labels to your script's custom fields, that are shown to the user in the Rename dialog. To do this, set this property to a Map created via the DOpusFactory.Map method, filled with name/label string pairs.
field_tips
object:Map
This lets you assign "cue banners" to any edit fields created by your script. A cue banner is displayed inside an empty edit field to prompt the user what sort of data the field expects. To use this, set this property to a Map created via the DOpusFactory.Map method, filled with name/banner string pairs.
focus
string
You can use this field to specify which control gets the input focus by default when your fields appear for the first time. Set it to the name of the desired control. You can also specify !oldname or !newname to assign focus to the standard old and new name fields.
