Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:scripting_reference:scripting_objects:getcopyqueuenamedata
If a script add-in implements the OnGetCopyQueueName event, the method receives a GetCopyQueueNameData object whenever a copy operation begins that uses automatically-managed copy queues (i.e. the Automatically manage file copy queues option on the Copying Files page in Preferences is turned on).
dest
object:Path
Returns a Path object representing the destination path of the copy operation.
desttab
object:Tab
Returns a Tab object representing the destination folder tab.
dest_drives
string
Returns a binary string indicating the physical drive indices that the destination path is located on (if any). For example, 00100000000000000000000000 indicates that drive C: is the destination drive.
move
bool
Returns True if the operation is a move instead of a copy.
name
string
Returns the default queue name for this operation.
source
object:Path
Returns a Path object representing the source path of the copy operation.
sourcetab
object:Tab
Returns a Tab object representing the source folder tab.
source_drives
string
Returns a binary string indicating the physical drive indices that the source path is located on (if any). For example, 00001000000000000000000000 indicates that drive E: is the source drive.
