Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:scripting_reference:scripting_objects:docmeta
The DocMeta object is retrieved from the Metadata.doc or Metadata.doc_text properties. It provides access to metadata relating to document files.
<column keyword>
variant
Returns the value of the specified column, as listed in the Documents section of the Keywords for Columns page.
