Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:scripting_reference:scripting_objects:winver
The WinVer object is retrieved from the Version.winver property. It provides information about the current version of Windows.
<default value>
string
Full Windows version string.
server
bool
True if running on a Server edition of Windows.
xp
bool
True if running on Windows XP.
xporbetter
bool
True if running on Windows XP or better (this will always be true).
vista
bool
True if running on Windows Vista.
vistaorbetter
bool
True if running on Windows Vista or better (later).
win7
bool
True if running on Windows 7.
win7orbetter
bool
True if running on Windows 7 or better.
win8
bool
True if running on Windows 8.
win8orbetter
bool
True if running on Windows 8 or better.
win81
bool
True if running on Windows 8.1.
win81orbetter
bool
True if running on Windows 8.1 or better.
win10
bool
True if running on Windows 10.
win10orbetter
bool
True if running on Windows 10 or better.
win11
bool
True if running on Windows 11.
win11orbetter
bool
True if running on Windows 11 or better.
