Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:scripting_reference:scripting_objects:viewers
The Viewers object is a collection of all currently open standalone image viewers. It can be obtained via the DOpus.viewers property.
<default value>
collection:Viewer
Lets you enumerate the currently open viewers.
lastactive
object:Viewer
Returns a Viewer object representing the most recently active viewer window.
Update
none
none
The first time a script accesses the DOpus.viewers property, a snapshot is taken of all currently open viewers. If anything opens or closes viewers after this, these changes will not be reflected by snapshot unless you re-synchronize it by calling the Update method.
