Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:scripting_reference:scripting_objects:tabstats
The TabStats object provides various information and statistics about the current folder displayed in a tab. Note that the Tab object provides two versions of this object. Tab.selstats takes Checkbox Mode into account, and in this mode the values of the "checked" and the "selected" properties will be the same. If the object was retrieved via Tab.stats and the file display is in Checkbox Mode, the two sets of properties will be different.
bigimage_h
int
Returns the width in pixels of the largest image in the folder.
bigimage_w
int
Returns the height in pixels of the largest image in the folder.
bytes
object:FileSize
Returns the total number of bytes in the folder as a FileSize object.
checkbox_mode
bool
Returns True if the tab is currently in Checkbox Mode.
checkedbytes
object:FileSize
Returns the total number of bytes in checked items as a FileSize object.
checkeddirbytes
object:FileSize
Returns the total number of bytes in checked folders as a FileSize object.
checkeddirs
int
Returns the total number of checked folders.
checkedexpanded
int
Returns the total number of checked items that exist within expanded folders.
checkedfilebytes
object:FileSize
Returns the total number of bytes in checked files as a FileSize object.
checkedfiles
int
Returns the total number of checked files.
checkeditems
int
Returns the total number of checked items.
checkedmusiclength
int
Returns the total length in seconds of all checked music files.
dirbytes
object:FileSize
Returns the total number of bytes in all folders as a FileSize object.
dirs
int
Returns the total number of folders.
expandedcontents
int
Returns the total number of items that exist within expanded folders.
expandeddirs
int
Returns the number of folders that have their contents expanded.
filebytes
object:FileSize
Returns the total number of bytes in all files as a FileSize object.
filedate_max
date
Returns the latest (most recent) file date in the folder.
filedate_min
date
Returns the earliest (oldest) file date in the folder.
files
int
Returns the total number of files.
items
int
Returns the total number of items.
largestfile
object:FileSize
Returns the size of the largest file in the folder as a FileSize object.
musiclength
int
Returns the total length in seconds of all music files.
selbytes
object:FileSize
Returns the total number of bytes in all selected items as a FileSize object.
seldirbytes
object:FileSize
Returns the total number of bytes in all selected folders as a FileSize object.
seldirs
int
Returns the number of selected folders.
selexpanded
int
Returns the total number of selected items that exist within expanded folders.
selfilebytes
object:FileSize
Returns the total number of bytes in all selected files as a FileSize object.
selfiles
int
Returns the number of selected files.
selitems
int
Returns the number of selected items.
selmusiclength
int
Returns the total length in seconds of all selected music files.
Update
none
none
The first time a script accesses a particular TabStats object, a snapshot is taken of the tab state. If the script then makes changes to that tab (e.g. it selects files, creates a new folder, etc), these changes will not be reflected by the object. To re-synchronize the object with the tab, call the TabStats.Update method.
