Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:scripting_reference:scripting_objects:tabgrouptabentry
The TabGroupTabEntry object represents a single folder tab. The folder tabs in a tab group can be enumerated via the TabGroupTabList object.
color
string
Returns the color, if any, assigned to this tab.
format
object:Format
Returns the folder format of this tab.
linkid
int
Returns the link ID of this tab, if it is linked to another tab. Both tabs will have the same link ID but otherwise the value is meaningless. Use the TabGroup.Link and Unlink methods to change tab linkage.
linktype
string
If this tab is linked as a slave, returns the string "slave".
locked
string
Returns the lock type of this tab. Valid values are "on", "off", "changes" and "reuse".
name
string
Returns the name of this tab if one is assigned. Tabs that don't have specific names assigned will usually show the last component of the path as their name.
path
object:Path
Returns the path that this tab will load when it's opened.
Duplicate
none
object:TabGroupTabEntry
Returns a duplicate of this tab entry.
