Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:scripting_reference:scripting_objects:tabgroup
The TabGroup object represents a folder tab group or a folder into which other tab groups can be organized. Individual TabGroup objects can be accessed or enumerated from the TabGroups object.
closeexisting
bool
True if the Close existing folder tabs when opening this group option is turned on for this group. Only present when the folder property is False.
desc
string
The description of this tab group, if any. Only present when the folder property is False.
dual
bool
True if the Define tabs on specific sides of a dual-display Lister option is turned on for this group. Only present when the folder property is False.
folder
bool
True if this object represents a folder within the tab group list, False if it's an actual tab group.
hidden
bool
True if this tab group or folder should be hidden from menus which list tab groups. The group will still always be visible in Preferences.
lefttabs
object:TabGroupTabList
Returns a TabGroupTabList object representing the tabs in this group that open in the left/top side of a dual-display Lister. Only present when the folder property is False and the dual property is True.
name
string
The name of this group or folder.
righttabs
Returns a TabGroupTabList object representing the tabs in this group that open in the right/bottom side of a dual-display Lister. Only present when the folder property is False and the dual property is True.
tabs
Returns a TabGroupTabList object representing the tabs in this group. Only present when both the folder and dual properties are False.
AddChildFolder
<object:TabGroup> or <string:name>
object:TabGroup
Adds a new sub-folder to this tab group folder. Only available when the folder property is True. You can either provide a TabGroup object (which itself has the folder property set to True) or the name for the new folder. If the operation succeeds a TabGroup object is returned which represents the new folder. If the operation fails False is returned.
AddChildGroup
object:TabGroup
Adds a new tab group to this tab group folder. Only available when the folder property is True. You can either provide a TabGroup object or the name for the new group. If the operation succeeds a TabGroup object is returned which represents the new tab group. If the operation fails False is returned.
DeleteChild
<object:TabGroup>
none
Deletes the child item (folder or tab group).
Duplicate
none
object:TabGroup
Returns a duplicate of this tab group or folder. When it's returned the duplicate has not yet been added to a tab list.
Link
<object:TabGroupTabEntry>
<string:type>
none
In a tab group that has specific left and right tabs specified, this method links together a tab from the left side and a tab from the right side. Only available if the dual property is set to True. You can provide TabGroupTabEntry objects or the index numbers of the tabs you want to link.
The optional type parameter can be set to "slave" to specify that the tabs should be slaved to each other.
Unlink
none
Unlinks the specified tab from its partner. Only available if the dual property is set to True.
