Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:scripting_reference:scripting_objects:styleselecteddata
If a script add-in implements the OnStyleSelected event, the method receives a StyleSelectedData object when the user chooses a new Lister style.
lister
object:Lister
Returns a Lister object representing the Lister that changing style.
qualifiers
string
Returns a string indicating any qualifier keys that were held down by the user when the event was triggered.
The string can contain any or all of the following: shift ctrl, alt, lwin, rwin
If no qualifiers were down, the string will be: none
style
string
Returns the name of the newly selected style.
