Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:scripting_reference:scripting_objects:storedquery
A StoredQuery object represents a stored query collection. It is retrieved by with the query property of the Item object.
This object lets you read and modify the query's parameters. Changes you make to the object will be reflected in the stored query next time it is read or its contents refreshed.
autoupdate
bool
True if the query auto-updates when it's read, false if it has to be manually refreshed.
engine
string
Search engine the query uses. As well as the engine itself, any options it offers can also be controlled. For example, "everything,case" would use Everything in case sensitive mode.
KeywordOptions
everythingcase, wholeword, matchpath, regex, diacritics
everythingglobalcase, wholeword, matchpath, regex, diacritics
windowsnqs,noauto
opusnonames,content,nowild,regex,anywords,case,nodiacritics,nopartial,utf8
paths
Vector
A Vector of paths that the query runs against.
query
string
The query string.
