Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:scripting_reference:scripting_objects:specialmeta
The SpecialMeta object is retrieved from the Metadata.special property. It provides access to any folder-specific properties.
For example, in file collections you can access the dateadded property this way to see when an item was added to the collection.
