Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:scripting_reference:scripting_objects:sortorder
The SortOrder object is returned by the Format.manual_sort_order property if manual sort mode is active. It lets you query and modify the sort order.
GetOrder
<string:name>
object:Vector
Returns a Vector of strings representing the current sort order of files in the folder. If multiple manual sort orders have been defined, you can provide the name of a specific sort order as an argument to this method. If called with no arguments it returns the current sort order by default.
SetOrder
<Vector:order>
<string:name>
none
You can pass this method a Vector of strings to change the sort order of the current folder. You can optionally provide the name of a sort order as the second parameter if you’ve got more than one sort order defined.
ResetOrder
<string:name>
none
Resets the manual sort order to the currently selected sort order (e.g. if the file display header indicates that it is sorted by name, ResetOrder would reset to filename order). You can optionally provide the name of a sort order as the second parameter if you’ve got more than one sort order defined.
