Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:scripting_reference:scripting_objects:smartfavorites
The SmartFavorites object lets you query the contents of the SmartFavorites table. It is retrieved from the DOpus.smartfavorites property.
<default value>
collection:SmartFavorite
You can enumerate the SmartFavorites object to retrieve individual SmartFavorite objects.
threshhold
int
Returns the number of points an entry must have before it would be displayed in the SmartFavorites list.
max
int
Returns the maximum number of entries that would be displayed in the SmartFavorites list.
