Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:scripting_reference:scripting_objects:shutdowndata
If a script add-in implements the OnShutdown event, the method receives a ShutdownData object when invoked on Opus shutdown.
endsession
bool
Returns True if the Windows session is ending (that is, if Opus is shutting down because the system is shutting down), or False if it's just Opus that is quitting.
qualifiers
string
Returns a string indicating any qualifier keys that were held down by the user when the event was triggered.
The string can contain any or all of the following: shift ctrl, alt, lwin, rwin
If no qualifiers were down, the string will be: none
