Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:scripting_reference:scripting_objects:scriptconfigchangedata
If a script add-in implements the OnScriptConfigChange event, the method receives a ScriptConfigChangeData object whenever the user modifies the script's configuration via the Preferences editor.
changed
Vector:string
Returns a Vector containing the names of the configuration items that were modified.
