Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:scripting_reference:scripting_objects:scriptcolorpair
A simple object that bundles two colors together (text and background).
backcolor
string
Specify the background color. This should be in the form #RRGGBB (hexadecimal) or RRR,GGG,BBB (decimal).
textcolor
string
Specify the text color. This should be in the form #RRGGBB (hexadecimal) or RRR,GGG,BBB (decimal).
