Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:scripting_reference:scripting_objects:runresults
This object represents the results of a command run via the FSUtil.Run method when told to wait for the command to finish. It allows you to capture the console output of an external command.
exitcode
int
Returns the exit code of the process.
stdout
string
Returns any data the command wrote to stdout.
stderr
string
Returns any data the command wrote to stderr.
