Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:scripting_reference:scripting_objects:permanentfilters
The PermanentFilters object provides information about the permanent file and folder filter settings (configured on the Permanent Filters page in Preferences). It is obtained from the GlobalFilters.permanent property.
enable
bool
Returns True if the permanent wildcard filters are enabled.
file
string
Returns the permanent filename filter wildcard pattern. If the wildcard is configured to use regular expressions, it will have a regex: prefix in front of the pattern.
folder
string
Returns the permanent folder filter wildcard pattern. If the wildcard is configured to use regular expressions, it will have a regex: prefix in front of the pattern.
